b18c1 from 97 gsr into 97 civ dx
b18c1 from 97 gsr into 97 civ dx what can i use from the gsr?
what can be use from a totaled 97 gsr (rear damage) to re-install it into a 97 civ dx? Can I reuse the front spindles, axles, hoses, gsr shift linkage, mounts?? please help if you can!!
What can be recycled!
Modified by wylls at 9:16 PM 1/15/2004
Re: b18c1 from 97 gsr into 97 civ dx what can i use from the gsr? (wylls)
you will need the axles, shift linkage, wiring harness, and ecu along with the motor/tranny. beyond that just take what you can.
Re: b18c1 from 97 gsr into 97 civ dx what can i use from the gsr? (Team 4R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team 4R »</TD></TR><TR><TD CLASS="quote">you will need the axles, shift linkage, wiring harness, and ecu along with the motor/tranny. beyond that just take what you can.</TD></TR></TABLE>
you wont be able to use the wiring harness off the integra cause its a 2 piece instead of the 1 piece off your civic.
The tranny mount you can use, but all the other ones including the torque mounts(from the A/C compressor bracket, and tranny mount piece thats urethane) you will not be able to use. They dont line up correctly(I tried)you use the ones off your civic also. Rear mount is too long by I think 2 inches? ECU, motor, tranny, axels, shift linkages, hoses too, but I would get new ones(unless the ones off the teg are good)
97civic_ls
07-19-2008 03:29 AM
AznInvasion
09-18-2007 04:10 PM
swaplighter
05-15-2004 10:56 PM
