HELP with wiring
Old Jan 15, 2004 | 07:03 PM
moridin2004's Avatar
Default HELP with wiring
Alright, here's the deal. After searching long and hard to find an answer, I've come up with nothing. I'm swapping a JDM B16A turbo out of an 89 CRX Si into my 91 STD Hatch. I've got pretty much all the wiring figured out except for this blue wire on the driver's side. The B16 was adjusted so the Si harness matched up. Anyway, there is this blue wire on the 8 pin round connector (C175 or C313 I think) that I have no clue what it does. There are also 3 yellow/black wires on the car side of STD harness (14 pin connector), one of which I know is a main relay wire for the injector resistor box, but the other two I'm not sure of. There is also a 6 pin connector on the passenger side of the car (connecting to the motor) for which I know only what 4 of the wires do. The other two are the red and red/yellow wires.
If any of you have any clue as to what the wires mentioned above do, help is very much appreciated.
Unfortunately the Euro Helms and VTEC Euro addition don't cover the Si or the DPFI diagrams that I need to figure this out. My Haynes manual is the same thing (I know where I should have put that sh*ty thing along time ago )
Old Jan 15, 2004 | 08:24 PM
Default Re: HELP with wiring (moridin2004)
Anyone???
SuperSlowEF8
Aug 16, 2011 06:30 AM
DVS Luder
Oct 11, 2007 03:47 AM
Hondaracer197791
11
Sep 26, 2005 06:44 PM
moridin2004
Jan 18, 2004 07:49 PM
