HELP ASAP!!! FUEL PRESSURE REGULATOR PEGGED PAST 100
Old 01-11-2004, 03:57 PM
d_mina's Avatar
Default HELP ASAP!!! FUEL PRESSURE REGULATOR PEGGED PAST 100
Today after gassing up my car...my car sounded funny...so i pulled over and listened for the sound...it was coming from the rear of my car so i figured it was my fuel pump...so i just drove it home..when i get home i see that my fuel pressure gauge reads past 100 pegged onto that little stick...is the gauge busted or my fuel pump busted...or the regulator?!?
Old 01-11-2004, 05:22 PM
Turbogixxer's Avatar
Default Re: HELP ASAP!!! FUEL PRESSURE REGULATOR PEGGED PAST 100 (teameracer3)
sounds like regulator. is the exhaust a black smoke? take the vaccum off the fuel pressure regulator and see if it is leaking from there. Also, throw a different guage on there and see if the guage it messed up.
Old 01-11-2004, 06:25 PM
H22EK's Avatar
Default Re: HELP ASAP!!! FUEL PRESSURE REGULATOR PEGGED PAST 100 (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">sounds like regulator. is the exhaust a black smoke? take the vaccum off the fuel pressure regulator and see if it is leaking from there. Also, throw a different guage on there and see if the guage it messed up.</TD></TR></TABLE>
He is right, if that is the case I have one for you if you need it!
Old 01-12-2004, 01:26 PM
MrParks's Avatar
what reg are you using? sounds like it took a ****
Old 01-12-2004, 09:34 PM
d_mina's Avatar
Default Re: HELP ASAP!!! FUEL PRESSURE REGULATOR PEGGED PAST 100 (HARTENG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HARTENG &raquo;</TD></TR><TR><TD CLASS="quote">what reg are you using? sounds like it took a ****</TD></TR></TABLE>
b&m commandflo
Something Funny
07-12-2006 07:58 PM
d_mina
01-11-2004 04:02 PM
_jester_
08-10-2003 10:26 AM
blykins
04-16-2003 12:22 PM
Quick Reply: HELP ASAP!!! FUEL PRESSURE REGULATOR PEGGED PAST 100
