i have a trany question
i have a gsr tranny and its missin second gear can i put a ls second gear in to teh gsr trannnny and will the ls chasising fit the gsr tranny
Re: i have a trany question (jdm_gsr)
LS casings and B16 casings are the same. I believe the GSR casing uses different shims for the diff, but I'm not positive. If so, just swap the shims from the diff to the case you are going to use. Somebody please correct me if I'm wrong
WHAT ABOUT THE GEARS I HEARD FIRST AND SECOND ARE CONECTED TO TEH SHAFT ORRR WHAT IF I TAKE THE THIRD THRU 5TH FROM THE GSR TRANNY AND PUT IT INTO TEH LS TRANNY
Jonathan_ED3
04-19-2002 12:06 AM
