Guys I need your expert advise with my H22 to my Civic Hatch
Wazzup everyone...
I just got my H22A engine from Japan. And it came with everything... Wiring harness, ECU, etc.. everything but the shell it self. And I want to put this engine to my hatch that has already have a B16A. The question is:
Is it better to use the wiring harness, ecu, etc. that came with the engine? or I'm better off using the existing wires and ecu that's already in my car.
Thanks...
Thanks...
Re: Guys I need your expert advise with my H22 to my Civic Hatch (jdmhonda5)
I just did the same swap in my 92 hatch, I also had the B16A2 in it. You will need to use your existing harness. Just use the H22 harness to take whatever you will need from it. Also, if you use a Accord shift linkage you will not have to cut as much of your console out.
1dopesi
09-14-2007 07:25 PM
