Ok well I did a search, couldn't find too many details..b16 into 2000 civic coupe
Guest
Posts: n/a
Ok, I'm thinking about trying to swap out my 2000 civic EX w/ Automatic transmission for a b16 OBD2 setup (with manual transmission). I've been searching all night and can't find much, only a couple links that all lead back to the same info from Hybrid Garage. This is so far what I think I need, please help.
Motor/Transmission/Ecu
Engine Bay Wire Harness
B-series Axles
B series Intermediate shaft
Shift Linkage
Manual pedal assembly/shifter/****
Clutch Master Cylinder, hydraulic clutch lines
Rear transmission mount (from SI transmission)
Manual Cluster (not necessary)
92-93 GSR Power Steering bracket, 96 Del sol AC bracket (not necessary)
Please if you could, tell me if I missed anything or post some helpful link information if you had any book marked. Thanks
B-series Axles
Shift Linkage
Re: Ok well I did a search, couldn't find too many details..b16 into 2000 civic coupe (illicon2003)
Sell it and buy a manual ex. You will save yourself a lot of time and hassle.
Ep1dem1c
09-23-2008 04:51 PM
je7civic
04-29-2002 06:50 AM
