Quick? Please Confirm(GSR in DA)
Old Feb 10, 2004 | 11:09 AM
Cjsls's Avatar
Default Quick? Please Confirm(GSR in DA)
Someone please confirm.
Im doing a OBD1 B18C into a 91 Integra(OBDO)
Im going to use Boomslangs OBDO to OBD1 conversion harness.
Im also reusing my ls harness and just making the necessary changes(adding/extending some wires)
Here's my question. Since im going OBD1 i must use an OBD1 Distributor right? If so, then i must clip off the old connectors from my ls distributor and switch em out w/ the connectors off the GSR distributor that's currently on the motor. Is this correct? I can't reuse the ls distributor because its OBDO right? Any help greatly appreciated. Thanks
Old Feb 10, 2004 | 06:31 PM
acy76's Avatar
Default Re: Quick? Please Confirm(GSR in DA) (cjsls)
I believe that you have to match ECU and distributor generations, at least for OBD0 and OBD1 swaps. The internals are different and the signals going to the ECU would be wrong if you mix them up.
Old Feb 10, 2004 | 06:33 PM
Cjsls's Avatar
Default Re: Quick? Please Confirm(GSR in DA) (acy76)
okay i found my answer, just use the gsr distributor and clip off the plugs. clip the plugs off the ls dizzy and repin onto gsr dizzy so it plugs into the ls harness. thanks tho
fireblaze2k1
Apr 28, 2009 08:25 AM
6doorsentra
May 30, 2006 07:12 PM
SupraRXZ
Feb 6, 2006 07:05 PM
egvtec
Aug 10, 2004 10:25 AM
