b18b swap help?......
Old Feb 17, 2004 | 11:33 PM
CIR_ej's Avatar
Default b18b swap help?......
need some help every1?
I bought a 93 dx 5spd coupe for $450.....the thing iz it had no dash(int. firewall area completely bare),no ecu/harness,no radiator and little miscellaneous parts missing. Im a novice when it comes to engine swaps-I've seen them done,but this well be the first swap I'v ever done Sofar I have pulled out the little d15 motor with no complications. The engine that I'm swapping into the dx well be a b18b(94-95ls) which I dont have yet......from all the info I have gathered it should be an easy swap in, using the teg parts(linkage,axles,mounts,etc.)
What concerns me is the wiring...how difficult will it be? Since the dx I have has no ecu/harness I have no map out(hands on guide) on how the wiring was situated from interior to the engine bay.
Do I need to get a dx ecu/harness? Does the B18b harness connect to the dx ecu? I am completely stumped on the wiring part?
I checked around on the forums,but it appears all swap/wiring info has only dealt with H22's, B16's and B18c ........wiring<--------??????....need help with the wiring. All info/help appreciated thnx
Old Feb 18, 2004 | 03:40 AM
b18bturbosoon's Avatar
Default Re: b18b swap help?...... (CIR_ej)
https://honda-tech.com/zerothread?id=751181
or you can just go to the search thingy at the top
then type in "b18b wiring help" that's what i put in and i found what you're looking for
peace out....hope you find what you're look for from that!
wfocrx
Jul 19, 2007 10:22 PM
Playboy07
Nov 1, 2006 01:43 PM
mr_hahn73
May 5, 2006 05:55 PM
integra6650
May 10, 2003 04:35 AM
