JDM to USDM ob1 to OB2 wiring harness?
Old Feb 17, 2004 | 07:44 AM
WreckedTeggie's Avatar
Default JDM to USDM ob1 to OB2 wiring harness?
Hey I was just wondering if you guys know of any custom built wiring harness that allow a ob2 jdm motor easily wire up to an ob1 usdm car. I know i am probably going to have to do it custom, but i wasnt sure if there are any people out there just making them for my type of situation? I am doing a 99-01 gsr jdm motor in a 94 ob1 usdm teggie.
Thanks
Old Feb 17, 2004 | 11:38 AM
Turbogixxer's Avatar
Default Re: JDM to USDM ob1 to OB2 wiring harness? (ThatHondaGirl)
First off, Welcome to the Hybrid forum.
Second, Why would you want a custom harness? JDM motors are *basicly* the same as USDM. What I would do is get a USDM OBD2 GSR harness and take the JDM harness off and put the USDM one on. The OBD2 harness WILL clip right in to your OBD1 chassis harness. IF you do not have ABS (RS model), there will be some plugs left over, do not worry about them. You will not have to cut and hack to the harness at all, it will be almost plug and play.
What ECU you going to use? Because OBD2 JDM motors do not have Vtec pressure switch.
Old Feb 17, 2004 | 03:17 PM
I dont have an ecu yet lol, but its a 94 teggie so ill be going w obd1. Thanks alot for the help. The motor i am gettin is obd2 though, so you're sayin it wont have vtec switch? How do i go about wiring that up?
Modified by ThatHondaGirl at 7:37 PM 2/17/2004
Old Feb 17, 2004 | 03:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatHondaGirl &raquo;</TD></TR><TR><TD CLASS="quote">The motor i am gettin is obd2 though, so you're sayin it wont have vtec switch?</TD></TR></TABLE>
JDM only, USDM have them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatHondaGirl &raquo;</TD></TR><TR><TD CLASS="quote"> How do i go about wiring that up? </TD></TR></TABLE>
IT matters what ECU you use, If you use the JDM one that comes with the swap, you will not have to wire it up. IF you use a OBD1 or USDM ECU, will have to get a USDM Vtec housing or a window switch to make Vtec work.
Old Feb 19, 2004 | 09:36 PM
Gr8Wyt3's Avatar
Default Re: JDM to USDM ob1 to OB2 wiring harness? (turbogixxer)
or just buy a ob1 usdm p72 and get it chipped from kenji , or p28 but i dont know if that will plug into a teg harness
Old Feb 20, 2004 | 11:19 AM
Default Re: JDM to USDM ob1 to OB2 wiring harness? (B18RCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18RCoupe &raquo;</TD></TR><TR><TD CLASS="quote">or just buy a ob1 usdm p72 and get it chipped from kenji , or p28 but i dont know if that will plug into a teg harness</TD></TR></TABLE>
If it is the SAME OBD, it will clip in.
raverx3m
Mar 2, 2013 05:22 AM
vtec4deaththo
Feb 11, 2009 09:10 AM
eddiecut
Aug 17, 2003 07:39 PM
Sukebei Oni
Jun 11, 2003 05:25 PM
Slopoke
Jun 19, 2002 11:07 AM
