b18c1 timing desperate help!
Old Feb 17, 2004 | 07:40 AM
3.3.3's Avatar
Default b18c1 timing desperate help!
is there anything i need to do with the distributor before putting it on? also, when i put the camshafts in, the are both kinda crooked (the "up" arrows are a facing towards each other a little)....how do i adjust that?
hope this makes sense.
Old Feb 17, 2004 | 08:24 AM
mingchi69's Avatar
I to Smooch Pickle
Default Re: b18c1 timing desperate help! (makS)
put your motor at TDC... by lying up the white line on your crank pulley to the little pointer. With that, your cam gears both should be pointing upwards exactly. If they are not, your cam gears are off a tooth or more. Do not start your car unless you are 100% sure that the cam gears are lined up correctly.
About the distributor, there is only one way a distribuotr can be put on. You just have to adjust it for timing issues though.
Old Feb 17, 2004 | 12:48 PM
3.3.3's Avatar
Default Re: b18c1 timing desperate help! (mingchi69)
how would i adjust the distributor>?
Old Feb 17, 2004 | 02:51 PM
b16ahybrid's Avatar
turning it clockwise or counter clockwise while the engine is running and while using a timing light
Old Feb 18, 2004 | 08:02 AM
3.3.3's Avatar
Default Re: b18c1 timing desperate help! (b16ahybrid)
thanks
Old Feb 18, 2004 | 01:14 PM
UNCVLZD's Avatar
Before twisting the distributor with the timing light, it has to be warmed up and you hafta have the diagnostic plug looped around (the one on the passenger-side footwell with two wires.)
thomas1214
Apr 1, 2008 12:05 AM
racer69
Jul 24, 2007 09:13 AM
92H23VTEC
Jun 15, 2007 07:31 AM
Hemi_powered
Feb 4, 2006 12:46 PM
lsvtec101
Mar 21, 2003 03:31 PM
