problems with zc swap(please help)
Old Feb 15, 2004 | 10:02 AM
4potnick's Avatar
Default problems with zc swap(please help)
I bought a 88hf crx shell. I put a zc motor in it and I am having problems getting it started. Any advice will be greatly appreciated. thanks
https://honda-tech.com/zerothread?id=764836
Old Feb 16, 2004 | 06:01 AM
jlicrx's Avatar
Default Re: problems with zc swap(please help) (4potnick)
i asked before - no response - what engine wiring harness are you using?
Old Feb 16, 2004 | 08:55 AM
kshymkiw83's Avatar
Default Re: problems with zc swap(please help) (jlicrx)
DIZZY, did you replace the dizzy when you got the engine? also check your timing and make sure it is correct, i had this problem with my ZC in my crx. ended up being the Cam Gear was fudged.
devonb456
Mar 19, 2009 06:23 AM
metal craft
Feb 26, 2007 08:02 AM
lshatch1.8
13
Jan 31, 2007 12:15 AM
The Destroyer
11
Dec 30, 2005 02:22 PM
SteveeeO
14
Sep 20, 2002 01:12 AM
