gsr resistor box?
Re: gsr resistor box? (Tim_go_fast)
GSR engines/ECU's are not designed around peak/hold injectors with a resistor box. They run saturated injectors without a resistor box as do most OBD1-OBD2 setups. So the answer is no you don't need a resistor box.
