which harness conversion?
Old Feb 19, 2004 | 05:57 PM
quaker's Avatar
Default which harness conversion?
which harness conversion would i need to put a 2001 motor into a 94 civic, the obd2 to 1 or obd1 to2?
Old Feb 19, 2004 | 06:12 PM
quaker's Avatar
Default Re: which harness conversion? (quaker)
i want to use an obd1 ecu with the swap
Old Feb 19, 2004 | 08:21 PM
IS3Fifty's Avatar
Your confused. You DONT need a harness conversion
The OBD2(2001 engine harness) will be a direct plug into you OBD1(car chassis harness). The only thing that you will need to do it get yourself a OBD1 ecu. It will plug directly into the harness that is plugged into your current ecu.
Old Feb 20, 2004 | 12:24 PM
quaker's Avatar
Default Re: which harness conversion? (TODAeg6)
thanks dude, no wonder nobody had i wiringharness that would work, i don't need one
CRXLST
Jul 24, 2013 11:51 PM
jubster007
Apr 23, 2008 08:45 AM
99JdmDc2
Aug 16, 2007 07:43 AM
