gsr cams into b16
Re: gsr cams into b16 (civic-si-2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-si-2000 »</TD></TR><TR><TD CLASS="quote">would i see any gains?</TD></TR></TABLE>
Yes. They are slight, but worth the effort in my opinion.
Re: gsr cams into b16 (Icey112)
They do make a difference, but very little. Some people that i have talked to didnt even notice a difference. I would suggest the 00-01 itr cams or any year ctr cams. They are the same, and both put out a decent difference without going too extreme. You can usually pick up a set from ebay or classifieds for $450-500 and sometimes you can even find a package deal for $550 with the valvetrain. GSR cams are okay, but for the little extra money i would drop in something with a little more of a difference. You wouldnt want to waste $60 on a headgasket and a day of installation only to be dissappointed.
Re: gsr cams into b16 (ThatHondaGirl)
yes the gain might be little but if you can get them for free or no more then $50. then i would do it for the time being and ive seen some people gain 8hp to the wheels for just a little tuneing and if you go boost they will work out good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatHondaGirl »</TD></TR><TR><TD CLASS="quote">They do make a difference, but very little. Some people that i have talked to didnt even notice a difference. I would suggest the 00-01 itr cams or any year ctr cams. They are the same, and both put out a decent difference without going too extreme. You can usually pick up a set from ebay or classifieds for $450-500 and sometimes you can even find a package deal for $550 with the valvetrain. GSR cams are okay, but for the little extra money i would drop in something with a little more of a difference. You wouldnt want to waste $60 on a headgasket and a day of installation only to be dissappointed. </TD></TR></TABLE>
why would u be changing the headgasket and wasting a day of installation? Changing cams should only take a couple hours and you dont have to take the head off.
Re: gsr cams into b16 (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 »</TD></TR><TR><TD CLASS="quote">
why would u be changing the headgasket and wasting a day of installation? Changing cams should only take a couple hours and you dont have to take the head off.</TD></TR></TABLE>
I was wondering the same thing when I read that.. heh.
Re: gsr cams into b16 (Hybrid93Eg)
if ever you want to go boost, they will make their difference then. i was boosted when i swapped in gsr cams in my b16, and it made a pretty noticable difference. mostly i got more wide range of torque and maybe a little less peak hp, nothing that wasn't made up for in torque though. noe im ls/vtec so they are even better suited.
Hmm .. i thought u had to take off the head... maybe i was just thinkin that bc when i was going na i was going to get machining done.. so obviously it had to be off ... shows wat i know... lol
