B18B swap
Old Feb 21, 2004 | 05:51 AM
89 JDM CRX's Avatar
Default B18B swap
First off i tried search but cant find info on obd1 swaps only obd0 stuff.
I got a 89 crx si , i will be converting to obd1 with a jumper harness so i can run hondata , now i've gotten all my obd1 parts but im just wondering about the wiring , from using my stock crx harness will all the plugs just plug in to the b18b stuff ? ie. sensors and all that . Any help or info is greatly appreciated as i will be doing this swap within the next two weeks .
Old Feb 21, 2004 | 07:00 AM
Turbogixxer's Avatar
Default Re: B18B swap (89 JDM CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 JDM CRX &raquo;</TD></TR><TR><TD CLASS="quote"> from using my stock crx harness will all the plugs just plug in to the b18b stuff ? ie. sensors and all that . </TD></TR></TABLE>
Yeah, some sensors you will have to splice connectors in (like ECT) but for the most part (besides converting it to OBD1) it is plug and play.
Old Feb 21, 2004 | 09:09 AM
89 JDM CRX's Avatar
Default Re: B18B swap (turbogixxer)
what's a ect ?
Old Feb 21, 2004 | 09:30 AM
Engine Coolant Temp sensor. OBD0 uses on the block, OBD1/2 uses one on the thermostat housing.
Old Feb 21, 2004 | 09:43 AM
89 JDM CRX's Avatar
haha that makes sense now , stupid early saturday mornings
Old Feb 22, 2004 | 04:37 AM
VTECVillain's Avatar
I have a 96 B18B1 in my 91 CRX DX but I used OBD0 parts to keep it simple. It's a daily driver, not boosted or anything so I saw no need to go OBD1. Basically your stock engine harness will be completely plug and play on the B18B1 other than the coolant temp sensor as mentioned and then the OBD1 parts that you'll be using (distributor, injectors, 4 wire O2).
Old Feb 22, 2004 | 05:16 PM
89 JDM CRX's Avatar
Default Re: B18B swap (VTECVillain)
ok good too know thanks for the info .
As for me going obd1 its because i will be going turbo as well with hondata , so i gotta convert to obd1
AdrenalineAngel
Oct 27, 2012 08:25 PM
e jay one
18
Jan 26, 2006 01:28 PM
DAlove
Aug 29, 2004 05:37 AM
kurinto
Jun 11, 2004 10:16 PM
gildo86
Apr 29, 2004 06:47 AM
