OBD I wiring in a EF!!!!
Old Feb 21, 2004 | 07:27 AM
awooooo's Avatar
Default OBD I wiring in a EF!!!!
Theres a wrecked EG 93 LX in my garage. I drive a 91 STD. I was thinking of taking that motor and puting it in my car. I would get 30 HP, MPFI and OBD I wiring. What would be the easisest way to wire this motor up? REuse my OBD 0 harness from the old D15 and just run a couple extra wires to the ECU? I already have a grey plug. How many wires would i have to run? What about the VSS sensor versus speedo cable? And what can i do on the OBD I dizzy? I want to reuse it but the plugs are different.
Old Feb 21, 2004 | 04:40 PM
awooooo's Avatar
Default Re: OBD I wiring in a EF!!!! (awooooo)
HELP me out guys
Old Feb 21, 2004 | 07:05 PM
-16V-'s Avatar
Dont waste ur time with that engine. I think thats why no one is helping you out.
Just do a mpfi swap first. Then that would open up the doors for endless mods.
But theres plenty of these topics in the archive search.
Good Luck
Old Feb 21, 2004 | 07:54 PM
mitsuman's Avatar
Default Re: OBD I wiring in a EF!!!! (1991_jdm_sleeper)
Id have to spend money on an ECU, y do that when i could just use the OBDI ECU.
Old Feb 22, 2004 | 04:31 AM
VTECVillain's Avatar
That's a lot of work for only swapping in a 1.5L nonVTEC motor. Most people convert to OBD1 in the EF's when going with B series motors and more high performance oriented setups due to the tuning benefits of OBD1. If I were you, I would only swap this if you feel like putting a little $ into it. I definitely wouldn't be using that 4spd tranny and the hydro LX isn't an option unless you want to make some custom mounts and convert to hydro. You'd be better off just sticking with OBD0 and doing the MPFI swap in my opinion. There will be a less wiring and hassles.
Old Feb 22, 2004 | 11:02 AM
Blown90hatcH's Avatar
http://www.JKOBDConversionHarness.com
Old Feb 22, 2004 | 11:04 AM
Mentat Ghola's Avatar
Default Re: OBD I wiring in a EF!!!! (VTECVillain)
(same guy different name) But i already have all the parts i need, if i were to convert my worthless 2 valve motor to MPFI id have to spend money on an ECU i owuldnt b keeping for long anyways. This swap would make things alot easier for when i save up for a OBDI B series or H series motor. I could have it all prewired right now, and later on it would be plug and play. I dont see how this would be aLOT of wiring, just 4-5 extra wires id have to run, and a reworked Distributor plug.
Old Feb 22, 2004 | 01:05 PM
Default Re: OBD I wiring in a EF!!!! (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">http://www.JKOBDConversionHarness.com</TD></TR></TABLE>
I already have one of these
Dasfinc
May 21, 2008 12:19 PM
trevor_gattenby
Jan 21, 2006 06:47 PM
Bseriesy0
Sep 21, 2004 10:14 AM
Ruby Civic
Jun 6, 2003 03:44 AM
Mentat Ghola
May 9, 2003 10:19 PM
