2000 si engine into 96 dx
Old Feb 15, 2004 | 12:23 PM
mix123's Avatar
Default 2000 si engine into 96 dx
Ok here's my question.....My friend has swapped a 2000 si engine into his 96 dx ek.... the wiring harness wasn't cut and the factory si ecu came with it. So shouldn't he be able to just swap out the dx ecu for the si's and use the si's wiring harness and be done with it? Im confused because now the tach doesn't work and neither does vtec.... or should he just use his factory dx harness and ecu and wire up vtec? someone pls. explain
Old Feb 15, 2004 | 11:27 PM
mix123's Avatar
Default Re: 2000 si engine into 96 dx (mix123)
And by the way...no vtec...cel is on...and idle bouncing....
any ideas on what we should be checking?
Grams0wnsyouz99*
21
May 13, 2006 08:17 AM
unlimited6986
Jun 6, 2005 04:36 PM
Bad89rex
Apr 22, 2005 06:09 PM
JeffNA
Nov 26, 2002 10:46 AM
JeffNA
Nov 25, 2002 07:14 AM
