cranking trouble
Old Feb 20, 2004 | 01:54 PM
thad
Guest
Posts: n/a
Default cranking trouble
here's the situation, the dizzy is bad so i'm not even worried about spark right now, but when i crank it it truns over very slowly and inconsistantly it seems like it's drawing more juice that it should, the battery is dead so i have it jumped, when i crank it the dash lights dim the VAFC turns off and the lights on the car it's jumped to go dim. i tried cranking without the spark plugs in and it its still slow but it is consistant. my compression should be in the ball park of 11.9-12.7:1, the rings have not yet sealed. i can turn it over by hand with just a bit more effort than a stock b16.
Old Feb 20, 2004 | 06:16 PM
who-got-rice's Avatar
Default Re: cranking trouble (thad)
may be worth checking the timing out, is it possible it jumped a tooth, had a friends honda shear off one of the keyways on a cam gear but it wedged back in and left the belt one tooth off, was doing kind of the same thing,. good luck,hope it helps out.
Rhys!
Oct 25, 2011 12:11 PM
honda_prelude_jay
Dec 30, 2008 06:26 PM
Zerophase
Nov 24, 2008 02:11 AM
thad
Feb 20, 2004 09:43 PM
thad
Feb 20, 2004 02:59 PM
