cable to hyrdo conversion
Old Feb 10, 2004 | 06:19 PM
thad
Guest
Posts: n/a
Default cable to hyrdo conversion
I've heard that there is a kit that allows people with a cable tranny to use a hydro without having to install master/slave, hard lines etc. from my understanding it is a bracket that replaces the slave cylinder and lets the cable control the throw out fork. does anyone know anything about it, ie: who makes it, where to get it, what is needed (hydro flywheel, clutch?)
T.I.A
Old Feb 10, 2004 | 06:22 PM
acy76's Avatar
Default Re: cable to hyrdo conversion (thad)
Try Hasport. Although they might only have the kit allowing cable clutch actuation in a newer hydro clutch chassis...
You could always do a gear swap too. That's what I ended up doing in my 91 Integra.
EDIT: As far as clutch stuff goes, you'll need a new disc if you do use a hydro transmission in your car (or a 92-93 cable LS)
Old Feb 10, 2004 | 06:46 PM
VTECVillain's Avatar
Check out the HASport EFB2 kit: http://www.hasport.com/Product...2.htm
Old Feb 10, 2004 | 10:27 PM
1slowcrx's Avatar
Default Re: cable to hyrdo conversion (VTECVillain)
just weld your own backet to controll the fork
Convert
Feb 1, 2009 09:51 PM
Sliced Beard
Honda Motorcycles
14
May 21, 2008 04:37 AM
92integracer
Jul 26, 2007 02:48 PM
Rukusmasta2
Jan 29, 2006 08:09 AM
dlric
Oct 22, 2002 08:21 AM
