ls vtec Knock Sensor
Old Feb 15, 2004 | 05:04 PM
kerby116's Avatar
Default ls vtec Knock Sensor
im doing a lsvtec swap into my 93 civic dx. does obd1 vtec ecus have a Knock Sensor? if so what will i need to do to bypass it?
Old Feb 15, 2004 | 07:04 PM
Turbogixxer's Avatar
Default Re: ls vtec Knock Sensor (kerby116)
All B-series ECUs have knock sensors (p30, p61, p72) but SOHC ECUs do not (read: p28). You can (it is ghetto, but works) a 13k resistor on the knock sensor wire. Get a P28 and you will be set.
Old Feb 15, 2004 | 08:56 PM
Ivan's Avatar
senior gold member
what I did with my was I put it where on the top alternator bracket. it did fine and the new owner of the car hasn't had a problem.
GSR-TRBO-DA
Aug 15, 2007 09:28 PM
dem0nk1d
Feb 13, 2007 07:11 PM
Phatch99
10
Jun 3, 2004 05:16 AM
SiHatchTurbo
Oct 11, 2003 10:24 AM
Doctor CorteZ
Feb 7, 2002 04:45 PM
