b16 crx to b18c
Crazy Honda Guy
The B18C is a great swap and should work just fine with a Y1 tranny. I take it your going to run OBD1, so all you really need to do is the wire conversion. Also, you may have to consider hood clearance bue to the taller block and what mounts you currently have. I have a Jdm zc hood on mine with a hasport kit which give my engine the room it needs with no rubbing.
Deetz
Deetz
i have the hasport kit also.....i was thinking about swapping heads to the b16, and milling it like 3 thousandths, to kit stock compresion, and i would liek to keep it as easy of an install as possible, so maby keep my pr3 ecu? is this possible?
ovsep86
05-03-2006 11:18 PM
HT Chaplain
01-22-2006 07:50 AM
Yell88CRXsi
11-11-2003 03:29 PM
BLK99VTECR
08-09-2003 04:54 PM
