IAC TEST???????/
Old Feb 11, 2004 | 03:50 PM
Convoy's Avatar
Default IAC TEST???????/
i heard about a test u can do to check if the IAC is messes up. my car idle surger from 1000-1500, what are the tests, i heard of one where u plug a hole in the TB and if the car doesnt stall then u have a vacuum leak, but what if the cars stalls, or worse the car dies. what does that mean.
the reason i ask is because when i plugged it the car died.
Old Feb 11, 2004 | 05:06 PM
Convoy's Avatar
up
Old Feb 11, 2004 | 06:50 PM
Hondaaccordvtec's Avatar
Default Re: (S.Convoy)
I had this problem w/ my JDM H22. It would jump idle from 1000 to 1500 constantly. I decided to pull the connection on the IACV - the result was the CEL light came on but the surging stopped. I plugged it back in and the surging started up once again. I checked the connections and probed the wires for the correct voltage and everything checked out on the IACV. My problem was the idle set screw on the throttle body needed to be adjusted. It was open way too much.
You might want to try this
Old Feb 11, 2004 | 07:19 PM
Convoy's Avatar
i did that but the screw is fine
Old Feb 12, 2004 | 07:54 AM
Convoy's Avatar
morning bump
Old Feb 12, 2004 | 08:08 AM
projectTeG's Avatar
clean the IAC
Old Feb 12, 2004 | 08:13 AM
Convoy's Avatar
did that amny times and nothing still does it
Convoy
15
Jan 22, 2020 04:54 PM
michaelsej1
18
Feb 21, 2011 07:13 AM
duceducecord
Nov 20, 2008 06:37 PM
kihun_cha
20
Sep 17, 2004 03:18 PM
1.8t
Oct 19, 2003 04:34 PM
