maintenence to do before swappin it in?
Im gettin an ls for my eg...its got like 80,000 miles on it ...i was just wondering wahat kinda maintence to do to the motor before swappin it in? i know i should change the timin belt and water pump...but what else? thanks!
Re: maintenence to do before swappin it in? (jdmgeorge)
I'm changing:
Distributor Cap & rotor
Spark Plugs
Spark Plug Wires
Water Pump
Oil Pump
Oil Pan Gasket
TB Gasket
Timing Belt
Upper and Lower Radiator Hoses w/ clamps
Oil (I like sythetic)
Manual Transmission fluid.
Spark Plugs
Spark Plug Wires
Water Pump
Oil Pump
Oil Pan Gasket
TB Gasket
Timing Belt
Re: maintenence to do before swappin it in? (DarkKnight[DMD])
since it has 80k on it, i'm assuming the previous owner probably didnt get around to changing the timint belt yet or pulling any major maintenance on it. here's what i suggest from top to bottom:
plug wires
plugs
cam seals(only if replacing cams-if it aint broke, don't fix it)
valve cover gasket
head gasket
oil pump
water pump
timing belt
rear main seal
oil pan gasket
all other belts
you may want to flush the injectors, change radiator hoses if they appear worn. use 10w30 regular oil since you'll be technically breaking the motor back in if you change the seals.
plug wires
plugs
valve cover gasket
head gasket
oil pump
water pump
timing belt
rear main seal
oil pan gasket
all other belts
1990 CB7
02-27-2017 11:40 AM
90R3x
12-05-2016 02:09 AM
