My h22 is stuck in limp mode
I just put A j-spec h22 in my 95 prelude si. It is stuck in limp mode. The check engine light is always on. It flashes code 22, witch is the v-tec pressure switch. I've changed the pressure switch and ecu, still the same thing. We did the trouble shooting from the manual and everything checked out. If anyone has any suggestions it would be greatly appreciated.
Re: My h22 is stuck in limp mode (joshb3480)
sounds like what mine is goin through u can calm the rough idling by messin with the idle adj. check the tps. Also mine right now is doin the same but i haven't installed my vtec and vtec oil pressure. Thats all i can think of because im just about in the same boat.
Re: My h22 is stuck in limp mode (blacktsi)
I don't remember him saying anything about a rough idle. Anyways, what year is ur engine, and what year is ur ecu? Also, make sure u got the vtec pressure switch wire wired up correctly, simple thing to check but do it anways, check ur oil. That's all I got for now.
