timing question d16y8 with p28 ecu
this isnt really explained any where and is not clear to me or probably most people
im about to do a d16y8 motor swap into an obd1 eg
and i plan on running a stock p28(d16z6) ecu, everything should be fine but the timming is where im questionable at
since the d16y8 motor timing is 12 degree's
and the d16z6 motor is 16 degree's , this is the p28 ecu i was going to use
what kind of problems will i have with the difference in timing or will it not matter?
do i need to get an aftermarket cam gear and correct the timing that way?
or
can i adjust the timing from the distributor and try to get it close to 16 degree's
or
can i just throw the stock motor in and stock p28 ecu and will it be fine?
all input is welcome, thanks
or
or
Re: timing question d16y8 with p28 ecu (ironcheftony)
Won't matter a bit I'm running a Y8 with a P28 and have not adjusted anything and the timing is spot on
Canadian_EF
10
04-15-2012 06:29 PM
hondaeg8
07-22-2004 09:29 PM
