95 Integra h22a Power Steering
I have a teg with and h22a in it and I have been researching for quite some time for info on what needs to be done exactly to have power steering on the car again. I have researched it quite a bit but cant find the info I need. If there is anybody out there that is running it or knows how to do it, please let me know! I have the avid racing mounts. Thanks in advance for any help!
Re: 95 Integra h22a Power Steering (captain134)
All u need is a power steering bracket and pump from a 97-01 prelude to do it, I had to shave a couple inches of my bracket though to keep the belt from scraping the frame, it's a tight fit, but it works.
Re: 95 Integra h22a Power Steering (JasonST)
would the integra pump be sufficient? and what bracket did you use or was it completely custom? What mounts are you using because I just cant see how there is room for a belt to run passed the frame. Thanks for you help!
Modified by captain134 at 10:56 AM 9/25/2006
I'm using Hcp mounts, and I don't know about the integra pump I don't think itl work, check jdmsh!t.com (with an i), it tells u what u need. And yeah it is a tight fit, I had to shave the bracket to get so the belt wasn't touching the frame.
