need help with JDM Type-R ECU and my 99-00 Si wiring harness... blue, green and gray dont plug in
i think that wiring harness that i do have is an 99-00 si harness.. i am not sure.. however i have a jdm dc2 (98 spec) ECU.. and the wiring harness wont plug into it.. the only one that goes in is the blue plug. do i need something else? or is this not a Si 99-00 harness? or how do i know if it is?
Re: need help with JDM Type-R ECU and my 99-00 Si wiring harness... blue, green and gray dont plug i
you need a OBD2b to OBD2a jumper harness if you are going to use that JDM P73 ECU....or you can get a ODB2b to OBD1 jumper harness get a P28 ECU and chip that for the Type R motor...
good luck
good luck
HondaPartsHero
13
11-24-2006 09:30 PM
