h22a1 wont rev past 6k
Did my swap, h22a1 from a 95 prelude into my 93 civic si. will hit vtec, but overall just lacks power. i eliminated as many cels as i could. i am down to one, the EACV. I eliminated the wiring and the cel for that only comes on once the engine warms up, or if you start trying to drive without fully letting the engine warm. when you get into it, it seems like the powerband just goes to 6k. i also eliminated the external coil by adding a msd sci 6300 and blaster coil ss. any ideas?
Re: h22a1 wont rev past 6k (frstbte14)
bump cause i have about the same issue with my h22a but getting cel for egr and i have the same lack of power and vtec seems weak?
okay, well it hit vtec hard today and got pretty quick. pulled all the way to redline. it only does this after the engine has reached full operating temperature. i think the eacv is to blame. that and i bumped fuel pressure 5 psi
Re: (frstbte14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frstbte14 »</TD></TR><TR><TD CLASS="quote">i cancelled out my egr, made a block off plate, and never had it plugged it. not running a code for it. only a code for the eacv</TD></TR></TABLE>if you have blocked off the egr valve,you will throw a code for it and it wont let you rev past 6k unless you are useing a ecu that does not need the egr.what ecu are u useing?For the eacv what are the two wire colors going to it?
Re: (danny_t66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danny_t66 »</TD></TR><TR><TD CLASS="quote">if you have blocked off the egr valve,you will throw a code for it and it wont let you rev past 6k unless you are useing a ecu that does not need the egr.what ecu are u useing?For the eacv what are the two wire colors going to it? </TD></TR></TABLE> Wrong u can rev just fine with the cel on for EGR, I've had it on for half a year now and I've been able to rev just fine, it doesn't put the car in limp mode.
Bertamus
09-27-2010 05:57 AM
Preludes'R'Us
08-03-2005 08:00 PM
