h22a1 won't rev past 6k
i got the hard part done, the engine is in, starts, runs, and drives. when i throw in the gas, though, it will not hit vtec, and will not spin past 6k. anyone else had this problem? what was your solution? when revving that high, car does not go into limp mode. i am running cel codes 6 and 10, ect and iat
Re: h22a1 won't rev past 6k (frstbte14)
i'm in the same situation as you. My set-up is different though. 00 EK w/ 99 JDM B18C-R. I also have CEL on throwing code 16 (Fuel Injection). I've done everything possible but it's still on.
For the record with we can't past 6K and VTEC not hitting that is "limp mode"........
HELP US OUT!!!!!!
HELP US OUT!!!!!!
That Code 6 is holding your revs back. The ECT is an essential sensor to the ECU.
Figure that out and your get the car out of limp mode.
Granny_shifter
18
09-17-2012 08:08 AM
