b16a obd0 into 94 civic ex
I got a 90 integra with a b16a obd0 in it, with of course, a cable tranny. I don't care for the car and was wanting to swap this into my 94 civic ex coupe. I'm sure it can be done, but don't want to have to figure it out myself. Are there any write-ups on this cause I wasnt able to find any. And yes I know a b16 isnt that great, but its better than my d16 that needs another transmission.
Re: b16a obd0 into 94 civic ex (whatsthatnoise)
You need a Bseries mount kit for your 94, and a hydro to cable tranny conversion kit. You need a OBD-1 distributor. Use your D-series engine harness on your b16 - just have to move the o2 connector to the back of the block; unravel the harness some, it'll work its way back. Oh, and if using the d-series harness, put the IAT connector between the 1st and second intake runners.
Drop in car, use header and axles from DA. plug in ECU, issues solved.
There are write-ups for this, just search a little more.
