s2000 cluster swap, then no turn signals??
ok this is a weird one i think... i wired up an s2000 cluster into my 93 hatch.. last week everything worked as it should, including the turn signals. today i plugged the cluster back in and noticed the turn signals dont work. everythign else is fine though.. heres a rundown of what i checked:
-no turn signals at all
-hazard button plugged in and hazards work
-all lights work, including corners etc and with the hazards
-changed the turn signal switch to a known good one and tested the old one and it was good
-changed the flasher relay to a known good one
-made sure wires were still wired together and plug was in all the way. i even disconnected one wire and played around with it, and made sure it shut off one of the arrows on the cluster with the hazards on, which it did
is there a turn signal fuse somewhere? i didnt see anything listed on the fuse box thing.. helppppppp
SupaMonkey
12-04-2013 10:27 PM
2LGSR
10-07-2010 08:35 PM
EGed up from the seat up
03-04-2009 04:13 PM
JDM96SpecCTR
09-27-2006 06:18 AM
