Doing LS/VTEC build up what oil pump should I run? Stock, GSR, Type R, CRV?
Building an LS/VTEC with a B18B and a B16 Head just wondering what oilpump I should run? A stock LS or can I go with a GSR, Type R or CRV? Which has the most pressure? Thanks
Re: Doing LS/VTEC build up what oil pump should I run? Stock, GSR, Type R, CRV? (kevmugen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevmugen »</TD></TR><TR><TD CLASS="quote">GSR or typeR </TD></TR></TABLE>
Thanks for the info, Do you know what the diferrence is in flow between the pumps
Re: Doing LS/VTEC build up what oil pump should I run? Stock, GSR, Type R, CRV? (DavidTurbo)
I believe the vtec pump has a few extra teeth. VTEC needs oil pressure so you should go with a vtech oil pump.
Re: Doing LS/VTEC build up what oil pump should I run? Stock, GSR, Type R, CRV? (TexasluvsHondas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TexasluvsHondas »</TD></TR><TR><TD CLASS="quote">I believe the vtec pump has a few extra teeth. VTEC needs oil pressure so you should go with a vtech oil pump.</TD></TR></TABLE>
LMAO yeah right.... since the oil pump is driven off the timing belt right? do you know the difference between a oil pump and a water pump?
just get any OBD2 b series pump they are all the same...
Re: Doing LS/VTEC build up what oil pump should I run? Stock, GSR, Type R, CRV? (JCushing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing »</TD></TR><TR><TD CLASS="quote">
just get any OBD2 b series pump they are all the same...</TD></TR></TABLE>
I just found your posting. I'm doing an LS/Vtec on my 95 integra. How has yours turned out? Was the build up smooth or was it a pain in the ****?
Thanks...Nancy
Thanks...Nancy
hybridpatient95
14
06-02-2005 10:11 PM
