Crx hydrolic clutch conversion questions **real deal hydro
Well this hasport cable-hydro conversion isn't working out for me. I'm using this kit in my crx, with an exedy twin disc. Pedal bracket's been re-enforced as well as the actual pedal. But i'm having a problem snapping clutch cables since it's so hard to press it in. So i decided to try and convert to a real deal hydro setup. I'm checking out Wilwood's pedal as well as there clutch master cylinder and it seems like i can get it to work. I have a question on what size clutch master cylinder i should get though. They have .625 .700 and .750" bore. Which size would you guys recommend getting? And do you think it'll work?!? Here are the links of the pedal i'll be using, as well as the wilwood master cylinder. Then i'll just run a stainless line to the stock honda slave cylinder. Pic of my setup as well for s**** and giggles if anyone can help me out that'll be great.
http://wilwood.com/Products/00...x.asp
theinfamouskonrad
22
10-12-2006 11:21 AM
theinfamouskonrad
10-05-2006 08:09 AM
