B18b1 installation
Old Sep 26, 2006 | 03:07 PM
Broken00Hatch's Avatar
Default B18b1 installation
Alright, I've tried to use the search feature, and even browsed on Google for a bit and I couldnt find anything..
I have a 00 Dx Hatch and a 96 LS b18b1 swap.. I have the swap installed, but what wire harness and dizzy am I supposed to be using? the 96 ls dizzy wouldnt plug into the original 00 dx wire harness so I took the plug from my old 00 y7 dizzy and placed all of the 96 wires in it minus the tach wire to temporarily fix the problem, it runs, but not correctly, it dies at stoplights and has a weird rev limiting range
Old Sep 26, 2006 | 05:30 PM
Default Re: B18b1 installation (Broken00Hatch)
anyone? need help asap, I need this beast running correctly
Old Sep 27, 2006 | 10:52 AM
So no one knows anything about this swap?
Old Sep 27, 2006 | 05:00 PM
I know someone can help me out with this..
Old Sep 27, 2006 | 05:04 PM
stevil_knevil's Avatar
i've got the same swap just done in my 98 hatch.....i got a 98 ls teg dizzy, and i'm running the stock computer, and it was running fine, and really strong for a few days, but now all of a sudden, my car is cutting out after 2k rpms, and if i get it past 2 - 2 & 1/2k rpms while driving, it starts shaking horribly, and idles around 2k and kinda fluctuates....really strange. ran great for a few days, not it doesn't run for ****. hopefully will be all figured out by this weekend. i'll update ya with any info i can get on it.
Old Sep 28, 2006 | 02:27 PM
Default Re: B18b1 installation (stevil_knevil)
your using your stock wire harness with a 98 ls dizzy?, how, the 96 ls dizzy plug is completely different?
Old Sep 28, 2006 | 06:57 PM
actually i thought it was the 99-01 dizzy that's different. that's when they changed to the smaller plug. just like the 99-00 civics did. and i don't know if this helps you out any. but i got my problems fixed on mine. i wired up the harness to convert it to a 2-wire IACV, from the 3-wire setup. Found a thread on here that explained it all, and 'quick spliced' 2-sets of wires to trick the ecu for the Crank Fluctuation Sensor, and now i'm running strong. if you're having idling problems, that may be the solution. it fixed mine. if you need any info or links to any problem you're having with your swap, let me know, and i'll try to help you out as much as possible. lata!
Old Sep 30, 2006 | 10:35 PM
Sure, more help would be appreciated
Old Oct 1, 2006 | 10:56 PM
anyone?
Old Oct 2, 2006 | 01:15 AM
4Door Life's Avatar
if you can, post some pics...
its easier to help if we can see exactly whats goin on...
Old Oct 2, 2006 | 07:31 AM
Slopoke's Avatar
what ecu are you using?
Old Oct 2, 2006 | 03:17 PM
Default Re: (Slopoke)
99-00 Si
Old Oct 2, 2006 | 03:19 PM
Default Re: B18b1 installation (4Door Life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4Door Life &raquo;</TD></TR><TR><TD CLASS="quote">if you can, post some pics...
its easier to help if we can see exactly whats goin on...</TD></TR></TABLE>
hmm, theres nothin to really post a pic of, the plugs wouldnt fit togeather cause of size variations, so I placed the 00 dx plug on the 96 ls dizzy, and put them togeather, but its not runnin right
Old Oct 4, 2006 | 06:44 AM
need help asap
Old Oct 4, 2006 | 11:23 PM
4Door Life's Avatar
any luck yet...?
are you able to cunsult a shop manual or something simular, this way maybe you can double check your pins in the plug to verify there correct or not... if you dont have a manual, i can send you one on a disc or ill even try to send it via e-mail... let me know if i can help you out... Brian
Old Oct 5, 2006 | 11:42 PM
no luck yet, but yes I had schematics for my 00 Civic and the 96 Ls, everything is matched up perfectly
Old Oct 7, 2006 | 05:19 PM
help, please
Old Oct 8, 2006 | 12:48 AM
zerovandez's Avatar
If I'm not mistaken, you are not supposed to use 99-00 si ecu with a non vtec motor like the b18b. Fuel maps are totally different and so is the fuel cut off for redline. Right?
Old Oct 8, 2006 | 02:42 AM
Default Re: (zerovandez)
currently using a Pr4 ecu, and switching them between each other makes no difference noticeably
Old Oct 9, 2006 | 02:22 AM
Default Re: (Broken00Hatch)
all these Honda-Tech experts and mechanics and no simple advice on how to install a LS motor into an 00 Hatch??
Old Oct 14, 2006 | 07:16 AM
zerovandez's Avatar
Have you checked your tming when changing the dizzy? I have an obd2 dizzy for a 98LS and it plugs to my 98dx harness just fine. There are a couple of fixes that you may need to apply to the harness for the crankshaft sensor and the IACV. Did you do those? IF not, go down to the ECU and wiring section in this link:
http://technet.ff-squad.com/
you have obd2b civic so go to the obd2 section. Which ecu are you using? try to find a 99-01 LS ECU. According to that link, OBD2a 96-98, and OBD2b 99-01 have different wiring. Sounds like your plugging your obd2b harness to a obd2a ecu. And make sure your using a 99-01 LS ecu and not an Si.
2low4dow
Apr 12, 2012 06:16 PM
justinwazner
26
Nov 16, 2010 06:11 PM
groovinmind
Jun 1, 2005 12:01 PM
