B18C JDM Type R into a EG6 Install Question???
I'm looking at swapping a JDM Type R B18C (that is currently in a 2000 Civic Si) into my eg6. Question is can I use the same motor mounts, axles, shift linkage from the 2000 Civic SI in my eg6? I have a GSR brake swap (hub assembly) if it makes any difference. Thanks, Ken
Re: B18C JDM Type R into a EG6 Install Question??? (socaleg6)
yea the axels will be fine if they fit the si, thmotor mounts are different on the eg6 though, im not sure which ones i now the right side mount is... but it should be pretty simple to figure out with a SEARCH! lol i just swapped my 97 with a jdm typer youll love it man. wiring will be the only trouble you should have along with the mounts gl
Re: B18C JDM Type R into a EG6 Install Question??? (rising_son97)
Thanks man!
So Axles - OK
Shift Linkage ?
Mounts ?
I'll try the seach again... Guess im not that smart but i do love ketchup with my taters!
So Axles - OK
Shift Linkage ?
Mounts ?
Re: B18C JDM Type R into a EG6 Install Question??? (BlueIntegraBoy)
Thanks BlueIntergaBoy
So Axles - OK
Shift Linkage - OK
Mounts - Not OK / Will a Hasport mount kit work?
Ken
So Axles - OK
Shift Linkage - OK
Ken
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">For the timing cover side mount you will need to get the cast-iron bracket from any 1994-2001 Integra GS-R and also the aluminum mount as well. You can use the mount from a Del Sol VTEC as well, but not the 99-00 mount because it is totally different.
For the rear mount you will need to use a 1994-2001 Integra rear bracket. The actual rubber mount that bolts to the rear subframe can be the stock civic one. Check the 99-00 mount first and see if it will work too though before you go out and buy an Integra one. I used an Integra rear bracket on my fiancee's B16A2 swap in 1999, but the stock 99-00 one might work too.
The topside tranny mount can be the Civic VX one - it is the same thing.
The front mounting brackets need to be from an Integra 1004-2001, but if you want to keep A/C then get the A/C bracket for a Del Sol VTEC model. the actaul mounts that bolt to the underside of the framerails need to be the stock Civic ones.
I would also insert the energy Suspension mount inserts while you've got the mounts out
If you get Hasport mount kit for an EG. There's also a picture diagram, but for some reason the SEARCH isn't working for me.
EDIT: It's working now.
EFhothatch15
10
06-26-2007 05:42 AM
TypeR0207
08-09-2001 02:22 PM
