trouble with h22
Old Sep 30, 2006 | 01:07 PM
crazi_E's Avatar
Default trouble with h22
in ek:
Ok well my problem starts when i turn on my car. takes a couple seconds to turn over. I wait for it to warm up and as soon as it does, it starts surging from 1000-1600..its realli annoying.
Also there is a hissing noise like there is a vac leak sumwhere but i cant realli tell where its cuming from. its sumwhere around the intake manifold by the butterfly valve.
On the throttle body i know of 3 valves that need hoses connected to them, but i dont have them on..i kno this might be causing my motor 2 surge but i covered them up and nothing. i have a map sensor block off so that hose isnt needed.
When i take off it seems like my pedal is super stiff so i try giving it gas and it harshly jerks the car forward. I tried adjusting the throttle cable and no solution. And while taking off when i get to 2k my car drops idle likes its dying then ill have to give it more gas to continue but it hesitates
When im driving i smell fuel, but i kno that my header has a crack in it. Any help to ease my car from this horror is appreciated
Modified by crazi_E at 9:47 PM 10/1/2006
Old Sep 30, 2006 | 01:08 PM
crazi_E's Avatar
Default Re: trouble with h22 (crazi_E)
will be at work until 1130 so i wont be able to respond til then
Old Sep 30, 2006 | 07:38 PM
crazi_E's Avatar
bak home
Old Oct 1, 2006 | 03:40 PM
Braco11's Avatar
any cels?
Old Oct 1, 2006 | 05:44 PM
crazi_E's Avatar
Default Re: trouble with h22 (Braco11)
yea im throwing egr but i have a block off
Old Oct 4, 2006 | 10:22 AM
crazi_E's Avatar
no more sticking pedal..throttle cable was spining and sticking
found out what was leaking with brake cleaner..have sum type of block off that was not sealed right..so imma juss silicone it up and see how it goes
smeags
10
Jul 20, 2013 10:22 AM
gtowni3
Sep 23, 2005 05:36 AM
civicfanman
Apr 25, 2005 07:56 PM
wanttorace
Sep 7, 2003 07:38 PM
Mikey3000
May 23, 2002 12:37 PM
