help me! no spark
Old Oct 7, 2006 | 02:08 PM
filip-s's Avatar
Default help me! no spark
I swaped my car s engine (d13 b1) with b 16 a 1,my b16 a1 came with an incomplete wire harness. It s missing the wires that go to the dash fusebox. I ve connected them all following the manual,and i ve also added the main relay. When i try to start the engine the fuel pump works,the engine has no spark or it gets one weak spark.
My distributor is getting power, I`ve hooked up the main relay, checked, and rechecked all the wires and nothing yet. Check engine warning light is on 2 seconds after I turn on the ignition, no error code, nothing.... The light on the ecu flashes once when I turn the ignition, but no spark at all
I`ve discovered today some wires in the distribuitor that are not isolated, and I believe this might be the problem, or....not.
Old Oct 8, 2006 | 10:50 AM
filip-s's Avatar
Default Re: help me! no spark (filip-s)
Somebody?
Old Oct 21, 2006 | 12:10 PM
filip-s's Avatar
I`ve checked all the wiering again, replaced the starter unit, distribuitor cap, and only 2 spark plugs are fireing. Somebody?
Old Oct 24, 2006 | 01:05 PM
filip-s's Avatar
problem solved!!!!
Old Oct 25, 2006 | 09:36 PM
albowskie's Avatar
how did you fix the problem? firing order or something? bad plugs bad ignitor or bad distributor
Old Oct 26, 2006 | 03:12 AM
filip-s's Avatar
Default Re: (albowskie)
Bad distribuitor and a bad link betwen main relay and blk/yel wire from fuse box
Up and running like hell
Old Oct 26, 2006 | 07:22 AM
albowskie's Avatar
yeah i swapped a b16a2 into my 95 coupe. first time it was the ignitor. and it ran after i replaced that. it was quick as hell. and i have never had vtec before and that **** is sick. but now i am not having any spark at all. so i tried three other ignitors and none worked so i am going to try a new distributor
vccasanova
Mar 24, 2013 11:34 PM
j4yzn
Aug 24, 2009 12:45 PM
filip-s
Oct 24, 2006 01:06 PM
psicrxsi
11
Oct 1, 2003 09:15 AM
