how do i swap a 93 b18c into 93 civic
I'm really 2slow
Re: how do i swap a 93 b18c into 93 civic (2FAST4U831)
You're gonna need all the mounts from a 94+ integra along with the rear transmission bracket. transmission, axles and shift linkage from a 94+ integra. ECU and header from a 94+ integra. A few wiring here and there for vtec
So, if you have a 94 b18c1 then it will be a bolt-in. No mounts needed. Just extend the Vtec wire and that is it I think.? Search"Katman" - he has has all the wiring diagrams
Re: (Varmit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Varmit »</TD></TR><TR><TD CLASS="quote">So, if you have a 94 b18c1 then it will be a bolt-in. No mounts needed. Just extend the Vtec wire and that is it I think.? Search"Katman" - he has has all the wiring diagrams</TD></TR></TABLE>
Depending on what civic he has and what ecu he is using, he may need to add wires for: Vtec solenoid, vtec oil pressure sensor, knock sensor, and IABs.
