H22 into EK Swap *PICS*
Wiring up the H22 (using P13 ECU and modifying the Civic harness)
I didn't have the bracket to hold the timing belt tensioner, so I whipped this up in a few minutes with a spare bracket, a hammer, and a cutting wheel...
It doesn't seem like it could fit!
PUSH! PUSH!
Modifying the power steering pump. I rotated the return line fitting and drilled a new hole to bolt it in. I had to trim the pump a little for it to fit.
First startup...
After I confirmed that it was running correctly, I detached the harness and loomed it up...
Cutting the hole for the shifter...
Shot from underneath...
There it is. Once the interior was installed you could hardly tell.
Exhaust installed. The cat-back had to be shortened to fit.
Installing the new fuel pump...
The P13 ECU just barely fits behind this trim panel.
All that needs to be done is the a/c and clean up the engine. It runs great and is VERY strong.
Thanks for looking See more of my swaps at http://www.phoenixtuning.com and http://www.getswapped.com
Re: H22 into EK Swap *PICS* (Dr Tweak)
Cool!, only thing= you should've done the H23 manual timing belt tensioner conversion. The autotensioner will fail.
Re: (Mikey3000)
the auto tensioner wont fail unless your modding the engine and putting out some big hp from what i hear. Nice swap im sure your be happy with it
Re: (Dr Tweak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Tweak »</TD></TR><TR><TD CLASS="quote">I spoke to the customer last night and he is very happy with it. His only issue is the 110 mph speed limiter! HAHA!
-Doc</TD></TR></TABLE>
chipped ecu will fix that
Re: (SB tuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SB tuning »</TD></TR><TR><TD CLASS="quote">looks good exept for the valve cover lol</TD></TR></TABLE>
werd!
werd!
Re: (88ED8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88ED8 »</TD></TR><TR><TD CLASS="quote">
werd!</TD></TR></TABLE>
i agree. y do all those valve covers look like ***. good looking swap tho man.
Re: (twotonecivic)
the auto tensioner will fail if you reuse them. It was an old factory defect and they recommend replacing them everytime. Even if you fill them back up with oil they still tend to fail, I have seen it happen to many times to to many of my friends. Replace it to be on the safe side.
Re: H22 into EK Swap *PICS* (atlplayer4life90)
i have seen a billion of these and they all say something diff ? which one is correct?
Wiring Chart ---- OBD1 OBD2 Function
orange -> dark blue CYPP
white -> white CYPG
orange/blue -> green TDCP
white/blue -> red TDCG
blue/green -> yellow CKPP
blue/yellow -> black CKPG
yellow/green -> yellow/green ICM
black/yellow -> black/yellow IGN Output
blue -> blue Tach Output
white -> white CYPG
i_eat_ROCKS
07-27-2004 11:41 AM
Tyson Ballou
09-23-2002 04:44 PM
jdmekcivic2eg
19
09-03-2002 12:37 PM
