********lsvtec timing belt covers.... HELP*********
Need help
what timing belt covers do i need?
upper(inner and outer) & lower
b18a block, obd2 oil pump
b16 head
Ive read that i need gsr/itr, and then ive been told b16, can anyone cofirm for me so i dont buy the wrong ones
Thanks
b16 head
Thanks
Re: ********lsvtec timing belt covers.... HELP********* (eastcoast_ej)
The lower cover needs to be the same as the block. the upper needs to be the same as the head(b16). If its the same as a b20 vtec the covers wont line up perfect, you will need to trim them at the bottom a little to fit. That's why most people don't run the upper on b20's and ls's. But that's for b20, It might be different for an ls. Hope this helps...
Fook_me_honda
03-27-2010 11:54 AM
