motor mount breaking
Old Nov 17, 2006 | 09:14 PM
thaipham806's Avatar
Default motor mount breaking
i have an eg6 and i did a motor swap to the b18c but recently ive been having trouble with the upper left motor mount because it keeps ripping. i have change the mount a couple of time but i get the same results. . need help!!!
Old Nov 18, 2006 | 02:02 PM
deryck324's Avatar
buy some inserts to make them stiffer and that should stop them from ripping
Old Nov 20, 2006 | 06:00 PM
Default Re: (deryck324)
is that the only way that it will stop doing it or what
Old Nov 21, 2006 | 06:26 AM
JasonST's Avatar
Default Re: (thaipham806)
It could be that the motor doesn't like where the mount brackets are and it has to put up with alot of tension to fit in each on, thus causing the mount with the most tension to break.
Old Nov 23, 2006 | 03:45 PM
Default Re: (JasonST)
its ok i ordered hasport motor mounts they should hold it nice !
Old Nov 24, 2006 | 03:30 PM
allmotorabe's Avatar
those are good motor mounts
95accordian
Feb 2, 2014 10:48 PM
Si Speed
Oct 6, 2007 03:03 PM
90Hatch
Nov 12, 2002 05:22 AM
P73 DA9
Jul 9, 2001 08:58 PM
