What is the best swap for a 92 Integra gen2 b18a1
I was looking a putting in a newer gsr motor, or a gen 2 b16 since it would make my car a xsi, what is the easiest swap to do without swapping out my tranny, my tranny is cable driven, and it is a non vtec. Any help would be appreciated.
Re: What is the best swap for a 92 Integra gen2 b18a1 (Boosted92DA)
the best way to go in my opinion would be to slap in a 94-00 gsr with a jdm xsi cable tranny or sir cablr tranny,you even use your stock motor mounts, or you could get the da mount kit from inovative mounts.Since you are already obd1 the wiring will be easy just add the vtec wires and a obd1 p72 ecu(gsr) and your set, that will be much faster than a b16, da's are to heavy for b16s im doing this swap in my 90 da im hoping to hit mid 14's with itr pistons itr valvetrain and loads of bolt ons.
