2000 CIVIC TOTALED AND WHAT TO SWAP PARTS TO MY 1993 CIVIC EX!!!
Well this sucks just total the EM1 but thank God I am ok!!! Well and thanks to my friend that sold me his 1993 civic ex for $450.00 LOLZZ!!!! running... I always had EK's and never had a EG ever... So first project car here we go... I start off by asking?? DOESS THE 2000 CIVIC SI FULL SUSPEN FIT ON THE EG all around? and WHAT DO I NEED TO FOR A COMPLETE B16A2 SWAP FOR THE EG..what kind of wiring,mounts,ecu,etc.... NEED HELP!! THANKS
Re: 2000 CIVIC TOTALED AND WHAT TO SWAP PARTS TO MY 1993 CIVIC EX!!! (igotjdm)
well to start out , dunno about the suspention , you need the top motor mounts and if the chassie didnt have vtec then you have to wire it in , you can use the harness and ecu
I'm a Jackass cause i dont like to follow the rules.
I'm pretty sure the suspension will transfer over to your '93 ex. as far your b16a2, you'll need b series motor mounts, axles, shift linkage, and i'd go with a p72 ecu. thats a gsr obd1 and will have your car run way better when tuned. i'm not sure if your thinking about keeping the interior, but would you sell me the rear seats and some interior pieces?
the ek front sus. will fit but the back wont. the lca are different, but if your just using the springs and not the shocks it would be fine.
Re: (ar3dd)
you can still use the rear disc...you just need to take off the hub using a star screw... i dont know if it called a hub... but it is do-able
because i took disc off of a 95-EX/ABS civic...it the same as TEGs
flychineseguy
09-22-2007 12:12 PM
90AccordVTEC
13
06-09-2006 07:03 PM
