Resistor Box ?
Old Nov 22, 2006 | 03:06 PM
oneslowstd's Avatar
Default Resistor Box ?
If the resistor box for a H22 EG hatch isn't hooked up will the fuel pump not work?
Old Nov 22, 2006 | 04:09 PM
SteveoBA8's Avatar
Default Re: Resistor Box ? (oneslowstd)
I dont think it would affect the fuel pump turning on at all, check the Main relay.
Old Nov 22, 2006 | 06:31 PM
Chem Geek's Avatar
Default Re: Resistor Box ? (SteveoBA8)
If you have the injectors that require the injector box, running without one can burn out the ECU. Which in turn could affect the fuel pump I guess.
Old Nov 22, 2006 | 07:54 PM
dc2vu's Avatar
Even if you burn out the ecu, the fuel pump will still turn on. Ask me how I know...
Old Nov 23, 2006 | 07:38 AM
oneslowstd's Avatar
Default Re: (dc2vu)
How do you know dc2vu?? lol No but really that makes sense I thought it would still turn on. But its not. Where is the main relay at?
Old Nov 25, 2006 | 01:15 PM
SteveoBA8's Avatar
Default Re: (oneslowstd)
http://techauto.te.funpic.org/mainrelay.php
Old Nov 25, 2006 | 02:25 PM
oneslowstd's Avatar
Default Re: (SteveoBA8)
Thanks bud!!! But wouldn't I hear the relay try to click if it was even getting power??? See Im leaning towards a bad ecu cause the, Engine light stays lit! No fuel priming and no other system checks. So what do you guys think? Much appreciation
Matthew Mullery
Honda Civic (2006 - 2015)
Feb 25, 2017 09:37 PM
B18C4-T
Aug 1, 2013 07:11 AM
C. Amick
Apr 4, 2011 05:36 PM
zeke mccune
Jun 14, 2004 02:48 AM
avividmemory
Sep 2, 2002 11:05 PM
