F22 block + H22 head, will it get lower or higher compression?
with an all stock components f22 block (I think 8.8 compression) with an h22 head installed will my static compression be lower or higher?
Thanks
Thanks
Re: (SB tuning)
ok, I am getting to f22 blocks for $50 and I was going to stick some 11.5 :1 standard f22 pistons in and slap an h22a head on.
Re: (dpine)
This is the coolest thing ever. Select the parts you want to use and it will spit out the basic numbers (CR, max piston speed, etc)
http://www.zealautowerks.com/hfseries.html
Re: (Prodigal Son)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prodigal Son »</TD></TR><TR><TD CLASS="quote">This is the coolest thing ever. Select the parts you want to use and it will spit out the basic numbers (CR, max piston speed, etc)
http://www.zealautowerks.com/hfseries.html</TD></TR></TABLE>
Doesn't seam very accurate at all
Re: (dpine)
Changing the head on the F22 block won't change the compression at all. I had thought it would raise it, but from what I've read it doesn't change at all. It is still 8.8;1
mhlamin
06-19-2008 09:08 AM
fastludeh22
08-11-2003 09:10 AM
