EF bseries. Searched!
Old Nov 24, 2006 | 04:17 PM
traction issuez's Avatar
Default EF bseries. Searched!
with a ctr crank pulley,
1. do you still have to bash the driver side shock tower in still?
if i do where is it? hasport website has only "X"es for pictures.
also
2. where does the rear cross member needed to be dent in also??
Thanks
Old Nov 24, 2006 | 06:16 PM
88 rex's Avatar
Default Re: EF bseries. Searched! (traction issuez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by traction issuez &raquo;</TD></TR><TR><TD CLASS="quote">with a ctr crank pulley,
also
Thanks</TD></TR></TABLE>
The CTR pulley has no affect on the fitment. The alternator pulley is why you bash in the shock tower wall.
Which mounts are you using? If you mount the rear mount on the rear subframe, it should be the little bit just in front of the mount.
Old Nov 25, 2006 | 10:49 AM
Default Re: EF bseries. Searched! (88 rex)
i'm using innovative b series mounts thanks.
Old Nov 27, 2006 | 04:25 PM
bigsubs's Avatar
I got a 91 civic w/ a 97 GSR and I cut a small section out on the rear sub frame also. DONT cut into the sub frame just cut the lip out and cut it about 6" wide also. For the record I'm using the e-bay yonaka mounts. As for the alternator clearance just lower the motor in and mark the ball park area. You'll mos def need a maul not a hammer cause it'll eat your lunch using a normal hammer.
Old Nov 27, 2006 | 05:51 PM
Default Re: (bigsubs)
thanks bro
GYChris
12
Jan 25, 2009 05:53 PM
LvN
19
Aug 24, 2006 02:39 PM
Combustion Contraption
Apr 11, 2005 10:26 PM
JohnnieChimpo
Feb 21, 2005 06:27 AM
Ricochet.
Nov 2, 2004 08:05 PM
