Which Distributor and Ecu to use for 96' d16y7 swap in 93 ex???
I was told to just use a 96 sohc non vtec dizzy and a P06? Is there any Obd1 dizzy that will bolt up? In my possession i have a obd1 ex and dx? 1 off topic stupid question....If i have a slack alternator belt will tha car still crank???
Technical Hero
Re: Which Distributor and Ecu to use for 96' d16y7 swap in 93 ex??? (UpNCominEJ1)
I would think any d series 92-95 distributor would work, except the Z6/D15B which would physically not line up all the bolts. You can use any 96up D series but you'll have to swap the plugs on the distributor for the 92-95 style because OBD2 plugs are different. The car will still crank unless you have been running it like that with the belt really loose and now the battery is not charged enough to crank.
Re: Which Distributor and Ecu to use for 96' d16y7 swap in 93 ex??? (HondaPartsHero)
I Have Fuel and Spark im jus not starting...its firing sputtering like its gunna start but doesnt...Other then tha dizzy wat could it be???
Sirex
03-18-2003 07:31 PM
