y8 harness to b16b ctr
first of all, i am not sure if this works. but if it does, I need help finishing my harness swap. the fuel injector housing looks like crap on the intake, theres a extra plug(below the housing) that i dont know where to plug it too. on the y8, theres a wire coming from the crank pulley to the alternator bracket which connects (plugs) to another wire on the harness. this plug doesn't connect to anything on the b16b because it doesn't have the wire coming from behind the crank pulley. theres are the only two places i found out so far. help me out.
Technical Hero
Re: y8 harness to b16b ctr (jherbie)
the wire on the alternator side sounds like the crank angle sensor. I don't believe the B16B has it. Not sure about the fuel injector housing unless you are referring to the Intake air temperature sensor unless I see some pics
Re: y8 harness to b16b ctr (HondaPartsHero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero »</TD></TR><TR><TD CLASS="quote">the wire on the alternator side sounds like the crank angle sensor. I don't believe the B16B has it. Not sure about the fuel injector housing unless you are referring to the Intake air temperature sensor unless I see some pics</TD></TR></TABLE>
here are two pictures, is this plug (top pic) the same as the one below (bottom pic)? whats the name of this part?
y8
ctr
if so, can i cut out this plug (ctr injector plug (middle one) see below)
and put it on the y8 harness (cut this plug, and replace with ctr)
because the plug on the y8 harness does not plug into the female in the second pic above.
Modified by jherbie at 4:55 PM 11/23/2006
y8
ctr
Bjm1118
03-12-2019 04:58 AM
jonathan13
04-10-2009 08:24 PM
