auto to manual conversion?? anyone know how???
1. search
2. read guide that you found within 2 seconds
3. follow that guide, and forget about this thread
this thread is pretty useless anyway, as by "auto coupe" im assuming you mean an automatic '91 ford escort coupe, right?
Re: (esco562)
you need clutchline.clutch pedal.shift linkage.manual tranny.a manual starter.flywheel.clutchset.clutch master cylinder.n maybe a conversion mount(thats wat I needed on my eg idk if its the same for eks).and I believe you may have to cut a hole for the shifter..time patience and its easy...
I'm really 2slow
Re: (ken2830)
you need everything from the manual car exept the engine. Shift linkage, shifter, transmission, special transmission mount, ECU, flywheel, clutch, clutch master cylinder, clutch slave cylinder, clutch hardlines, 5 speed pedal assembly, 5 speed starter. There was nothing hard about this swap when I did mine. The hardest thing was looking for the damn parts You are gonna need to drop your steering column to change the pedal assembly.
Re: auto to manual conversion?? anyone know how??? (esco562)
I'm really 2slow
Re: (esco562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esco562 »</TD></TR><TR><TD CLASS="quote">ohh, i see damn sounds like a mission.. well im thinkin about it, any tips and advise i can get would help, thanks guys
honda-tech </TD></TR></TABLE>take your old engine and transmission out before doing it
97 DC2
01-07-2011 12:48 AM
