b20/vtec
Old Nov 29, 2006 | 12:08 PM
4doorluv's Avatar
Default b20/vtec ctr
can you use a B20 block with CTR internals and cyl head? I'm worried that the rods might be to long and the copression ratio would be too high (12.5-1 +)?
Old Nov 29, 2006 | 12:09 PM
doood's Avatar
been there done that
Default Re: b20/vtec ctr (EKguru85)
you would be destroking it by using ctr crank and rods
Old Nov 29, 2006 | 02:25 PM
Bense's Avatar
ctr pistons = 81mm
b20 pistons = 84mm
hmmmm
Old Nov 29, 2006 | 02:59 PM
.Grimace's Avatar
footwork mastery
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">ctr pistons = 81mm
b20 pistons = 84mm
hmmmm</TD></TR></TABLE>
and your point is j/k
Modified by Gremice at 7:52 PM 11/29/2006
Old Nov 29, 2006 | 05:37 PM
SilverGT's Avatar
Default Re: (Gremice)
I think he was assuming the rod and crank in b series are all the same, but from a hondfa newbie like me I think they are different some how.
Old Nov 29, 2006 | 06:14 PM
egsicx's Avatar
Default Re: (SilverGT)
You can use the b18 or the b16 head. Pistons are none compatable.
Old Nov 29, 2006 | 06:17 PM
EK FLY's Avatar
i would love to run a ctr head with a b 20 block and some 84 mml rs(ctr style pistons )
that thing would kick ***
Old Nov 29, 2006 | 06:38 PM
Bense's Avatar
or just get a h22
Old Dec 1, 2006 | 08:30 AM
4doorluv's Avatar
Default Re: (Bense)
thank you for the info i have a b16b in the car already so now i'm just deciding where to go from here. i'd like to stay all motor but i know ls/b20 blocks can't handle upwards of 8500rpm, so maybe a ITR block and ITR internals?
Old Dec 1, 2006 | 08:54 AM
doood's Avatar
Default Re: (EKguru85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKguru85 &raquo;</TD></TR><TR><TD CLASS="quote">thank you for the info i have a b16b in the car already so now i'm just deciding where to go from here. i'd like to stay all motor but i know ls/b20 blocks can't handle upwards of 8500rpm, so maybe a ITR block and ITR internals?</TD></TR></TABLE>
you do realize your b16b is a destroked itr engine? throw in an itr crank, rods, and pistons and you basically have a stock b18c5.
Old Dec 1, 2006 | 09:06 AM
Bense's Avatar
get gears
manoloek9
13
Aug 8, 2010 06:36 PM
JFG Kevin
Sep 11, 2006 10:38 PM
Civic_On_Bumps
Mar 19, 2006 05:06 PM
todaspecsi
Mar 23, 2004 07:55 AM
willyboyK20
Apr 16, 2002 10:23 AM
